Currently reading:
Wood hearth
Discuss Wood hearth in the UK Tiling Forum area at TilersForums.com.
Q
quick draw macgraw
Hi,
Job tomorrow tiling floor and up over wood hearth but cant figure hearth in my set up with regards to centering it as i am governed by an expansion joint so my question when i follow the pattern over hearth and the edge on the top has to be cut to follow the pattern do i lay the riser over the edge or use trim.
Just wondering what would look like with riser covering the edge rather than the top covering the riser edge if you catch my drift.
Or should i just use trim?
Thanks Steve.
Reply to Wood hearth in the UK Tiling Forum area at TilersForums.com
