Discuss When to remove spacers (metro tiles) in the Canada Tile Advice area at TilersForums.com.
C
cornsack
If poking spacers in between metros (leaving them sticking out the front) is it better to remove them before the adhesive has set rather than trying to pull them out the next day after compression?
If so is there a good way to tell when is safe to do without the tiles moving?
Dumbo
If you have been fixing mosaics to a good background and not having to build out any hollows in the wall you should find you can take them fsirly quickly ., depending on what adhesive you have used
C
cornsack
Thanks! Much obliged.
If using a standard set with ceramic metros would it be safe to leave overnight and remove in the morning or still best to take out sooner than later
Dumbo
Easier to take them out sooner, the metros will draw moisture from the adhesive making them unlikely to slip down pretty quickly .
Reply to When to remove spacers (metro tiles) in the Canada Tile Advice area at TilersForums.com
