weird problem
It is just as you guys think..its the moisture from the adhesive and grout causing it to swell slightly and dry back but still leaving the hump......I tend to either take the wood cill off or board over with plasterboard........also if leaving the timber cill on then it is worth putting a couple of extra fixings in to make sure it is solid....
Dave you dont need us lot mate you have been around to long lol
you should always use rapid on timber even ply as you can get the same problems😛ete
we have had same problem now we plasterboard the window sill but if you have tilled the walls you will not want to remove the wall tiles you may get away with screwing 4 mm ply on the window sill then tiling over it
Dave could the cill still swell if it was a painted surface ?
4 mm backerboard would be better ply would have to be glued and screwed to stop it daminating😛ete
Tank the bugger. It may well be Mrs Jones sunday roast gives off a lot of steam on the windows, which falls as condensation on the sill, soaks in the grout, through to the timber, swells it and lifts the tile. No matter what adhesive you used it'd do it if the timber was subject to moisture. Softwoods moreso than hardwoods.
You could also remove the timber fully with your Fein (or similar) and plasterboard / marine ply it and then prime well or tank it and try again.
Tell Mrs jones she had better tell every friend she has about what a good tiler you are in return for all this mucking around!
weird problem
penno,
penno,
