Currently reading:
Weight Check
Discuss Weight Check in the Australia Tiling Forum area at TilersForums.com.
Wishiwasatoptiler
1,118
Northeast
Hi lads and lasses, just wanted to check on weights,
Been asked to fix these, 600x300x10mm porcelain, these are the largest ill have fixed by far so want to make sure the weights ok for the board, to be fixed to moisture board, tanked with ardex tanking. so I've a 32kg weight per m2 both with board and also same with the tanking. Correct? I know the boards fixed sound as I've re boarded it.
So anyone know what weight these tiles will be per m2 and also am I right in thinking adhesive will be around 4kg /m2? cheers d
Wishiwasatoptiler
1,118
Northeast
Why would u use a rapid adhesive on the wall mate?
There's no need. And it'll make hard work of it.
Wanted to push the job on as had left myself short on time for another job, who's rang a number of times to check I'm still coming. So wanted to push on, but did think I might struggle, so second opinion and its off the purchase list. :oops:
Then the customers who's been ringing calls today to postpone as she needs to get a sparkie in as her DIY husband has replaced the socket fronts wrong in the hall I was to skim... lol... so I can chill and tackle these first for me porcelain tiles with time pressure.
Cheers for your input fellas, much appreciated.
Reply to Weight Check in the Australia Tiling Forum area at TilersForums.com
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
