Currently reading:
wall preperation
Discuss wall preperation in the Australia Tiling Forum area at TilersForums.com.
Hey David,
thats almost a "how long is a price of string" question! Every job would have to be taken on its own merit. Your a joiner, sure your trade is no different. I've used all of the above methods before plus more! If it's an enclosed space I've over boarded with 6mm Hardie. If not I've skimmed walls flat with adhesive before leaving for the day and packed them out as I go. It's all about aesthetics! If you're a shuttering chippy you won't get it, but if you're a second fix joiner then u will! Take a route you're comfortable with. That'd be my advice.
Generally FLAT works fine...... Unless it doesn't! You already know the score! :thumbsup:
David Rowell
Hey David,
thats almost a "how long is a price of string" question! Every job would have to be taken on its own merit. Your a joiner, sure your trade is no different. I've used all of the above methods before plus more! If it's an enclosed space I've over larded with 6mm Hardie. If not I've skimmed walls flat with adhesive before leaving for the day and packed them out as I go. It's all about aesthetics! If you're a shuttering chippy you won't get it, but if you're a second fix joiner then u will! Take a route you're comfortable with. That'd be my advice.
Second fix 3fall couldnt stand doing shuttering all day long I dont think id get any job satisfaction like. Cheers for the pointers :smilewinkgrin:
White Room
What:yikes:
Reply to wall preperation in the Australia Tiling Forum area at TilersForums.com
