L
Lil Dee
Hi guys/gals,
I hope you don’t mind me kind of barging in on your forums, but I can see an awful lot of help and experience being shared out and I wondered if you could help me out too ?
My newly built orangery is 300 x 380cm, with bi-fold doors at the front, four large-ish windows, and a “lantern” style glass roof (with a flat roof design surround).
What I’m hoping is that you can guide me in selecting the right kit to provide me with an UFH product that works for me. My orangery has been constructed with a (I’m copying from my quote here) “traditional timber joists floor with moisture resistant tongue and groove boarding” so I won’t be installing onto a concrete base, which is what I’m struggling with, as this is what most of the advice that I've found, refers to.
I have done some reading, and I know I’ll need to put down some floor insulation (like EkoBoard) on top of the existing T&G floor. And, as I’m looking for the UFH to be my primary heat source in the orangery, I’m thinking I need to install a 160-200w system. On top, I am hoping to find a good quality laminate, with a limestone or tavertine finish (or similar) which can cope with the UFH.
I would appreciate any suggestions you can make, and anything for me to look out for. A couple of things I’d like to point out :
1. I am a complete novice. I have no idea how I put the floor insulation down....do I nail it, glue it or what !? And how do I know what depth of baord I need to buy ?
2. Is the UFH matting the best option for me, or could I cope with laying cables ? I take it that I would still need to stick the matting down with the special tape that I would for the loose wiring ?
3. I know about the Part P certification, so I know to get a pro in to do the final connection for me (I have had the electrics installed as part of the build) In the meantime, I take it there’s no reason we can’t lay everything ourselves, and check it all out if we have a multi-meter handy ?
4. What level of UFH heating do I look to go with 100/160/200w ?
5 Is there anything I’m supposed to lay on top of the UFH before I lay the laminate ?
Apologies for the loooong first post, but I’m trying to cover all bases before you all get bored of me !! I hope that you don’t mind me coming along and hassling you all like this.....
Thanks in advance *crosses fingers* LD
