Tuff Form
Hi guys had a little thread going in the Tilers forum asking for a it of advice on tanking the former with Kerdi, but Im happy that has now been solved. Got a it of another issue/query my bathroom is roughly 2.5m x 2m in an old 1906 tenement flat my joists are running along the longer wall of the room an are roughly at 400mm centres.
The issue I'm having is they are all un level from each other, because of this I decided to put down 25 wbp ply and pack under the ply until it was level. I've done this and now have the ply level in each direction and am happy with that. But when I sit my former on the ply is seems to sit flat on the outside edges but the centre isn't lying flat on the ply it's as if it's sprung up or the board has a twist or something in it? I was thinking about glue it down and using some weights to hold it down?
Any ideas?
Contact the supplying company? Wooden trays sound like trouble to me. Prone to moisture warping, expansion, contraction blah blah blah! also could be bent if you've stored it on its side rather than flat? just to rub salt in, i installed a wedi fundo tray last week. Absolutely perfect. The customer had bought a generic version for about a hundred quid less, but it was like a banana! You get what you pay for. Or if you've paid well, you should have a decent tray.
Sorry it's not a wooden tray it's grp should have mentioned that
It says in there installation instructions you can add additional screws on the surface to eliminate flexing but Seems to me it should lie pretty flat out the box?
Aah sorry. Mixing you up with someone else in here. Yes grp trays like impey can need a few extra screws to pull them flat. Just be sure to waterproof over any screw holes. It's part and parcel of those trays. Follow the instructions to the letter and you'll be covered if it fails.
Be sure to lightly sand the surface and use kerdi-coll to fix the kerdi. Grp is notoriously problematic for adhesive.
Tuff Form
Tanking and Wetrooms
Tags Tags
None
Sandwich1987,
Sandwich1987,
Sandwich1987,
Sandwich1987,
