Ballu102
Hi
This is my first post so forgive me if my terminology is not correct Ok so after three years completing my bathroom project, yes that was three years………..I have finally got it to the tiling stage. :hurray::hurray:
It’s a relatively small bathroom with an L Shaped bath, which has a dry lined wall along one side (Length) and a stud partition along the width. Elsewhere in the bathroom I have a stud wall (Length Bathroom) which has a vanity unit installed so tiled area will only be 3sq meters max as this wall will also have a large mirror to give the effect of more space. The end wall is again a dry-lined wall with a very small window, max coverage would be 4squre meters.
All walls have been skimmed…………………..
I was hoping to tile from floor to ceiling with Travertine Tiles, but after reading some of the other post I’m a bit worried with regards to the weight etc. on the stud walls. The last thing I need is for a 600 x 400 Travertine tile to fall off and go through the bath !!
So any advice or recommendations would be really appreciated, failing using Travertine what other tiles would you recommend that would give a similar effect but not as heavy, as I have now tiled the bath panel and vanity worktop in Brick Mosaic Travertine tiles.
Many Thanks in Advance
Ivor
Ivor
