Discuss Tiling onto chipboard, opinions?? in the Australia Tiling Forum area at TilersForums.com.
mikeyd859
Hi guys.
I have always plied floors before and a customer asked me a question that i wasnt 100% sure on.
'why will adhesive stick to ply and not to chipboard'?
i rang my local supplier just to make sure that i was correct and one guy i spoke to said no adhesive wont stick and another said it will with primer.
just wondered if anyone can shed any light on the situation?
cheers mike
White Room
I found some adhesives stick to chipboard (not something I do) but it's the long term effect if moisture gets in will break down the chipboard.
Chalker
1,058
Tadcaster
Adhesive sticks very well to carpet! But it's not a very good substrate.
chipboard is not as stable as ply and breaks down when wet.
Dave
Subscribed
1,000,000
Co.Durham
Adhesive sticks to the surface of chipboard no probs but with it being a particle board , then that is where the problem is , it isn't structural stable enough to 100% hold the tiles in-situ , other particle boards like OSB are the same .
some will say an elastomeric adhesive will work but if the particles give , then so will the tiles... So imo why risk it.
mikeyd859
thanks for that guys. at least i can give the customer a decent explination if anyone asks again :)
widler
1,328
England
I can understand hardie on chipboard cos you screw it .
What holds ditra down when/if the addy fails on the chipboard ???
I
Ian
It would normally be glued to chipboard with a product like Ardex af200, proper sticky!
Reply to Tiling onto chipboard, opinions?? in the Australia Tiling Forum area at TilersForums.com
