V
vartegrich
I'm embarking on a tiling mission in my kitchen and stumbled upon a slight problem with the window sill.
The sill has a 15mm drop on the left and a 5mm drop to the window frame. My initial idea was to re-level the sill using compound, however if I do this, the tiles will sit nearly level with the window bead (pvc window) more-so on the left as the window is slightly out.
Do you think this would be acceptable? Or, any other suggestions willingly accepted.
