Tile Lippage
Hi Daz
Right i have scraped nearly all of the adhesive away and when i lay a dry tile it sits 2-3mm lower than the surrounding tile. Is this sufficient? Would i need to prime the area?
Do you offer your services in Norfolk as i may give in and pay to have the work finished off as i can't spend another day removing tile adhesive LOL.
Neil
If the tile is sitting 2 to 3mm lower then you'll be fine. The adhesive will give you a couple of mm so the tile should sit pretty good (you may need to bed it up a tad).
Norfolk is a bit too far for me, but if you really do want to get a professional tiler to quote to finish it, then send Dave a pm and he should be able to sort someone out for you.
Hi Dan
I'm away for the week which is just as well because its breaking me and that's coming from an amateur boxer!
I have pulled up all but one of the out of level tiles (7 x tiles) and removed the adhesive from 5 which took 4 hours. I had to stop because my neighbours complained of the noise (I live in a flat). So I have 3 left to do and one is still fixed so that's going to be a drama I'm sure as I have found the SLC is breaking up if I hit the bolster too hard.
Once I finish the donkey work I'm calling a tiler in to do the skilled stuff as I can't go through this again.
If only I patted my self on the back after finishing all the substrate work and passed on the tiling work I would have felt some achievement - unlike now.
Fair enough mate. I wouldn't worry about it, I think you're expecting a lot from yourself thinking you'd get it the same as a professional would. In many cases DIY-wise we find they're happy with saving lots of cash and putting up with a few lips but like myself, it seems it would bug you, and you questions it, got it confirmed that it wouldn't be acceptable at a pro level and to be fair you've done well in doing that. You'll have a pro job, and you would have saved yourself a few quid overall perhaps.
Don't kick yourself mate. You've done well. :thumbsup:
Perhaps it's the boxer coming out in you 😉
Tile Lippage
actionjackson,
PJPro,
actionjackson,
PJPro,
