Discuss STud Wall in the UK Tiling Forum area at TilersForums.com.
absolutely not, far to unengineeredHello all.
i am planning on taking some old plaster off the wall and building a stud wall out of 2 x 1 timber, with 9mm plasterboard screwed in. Will this be ok to take the full 30 odd KG per square meter?
my apologies,i thought you were planning on making a stud partition wall out of 2 x 1:lol:dot and dab onto brick. i am trying to keep the width down otherwise i will have to move the door frame over to allow for it. thats why i was wondering if i can use thin timber with loads of fixings to make it as strong as possible. i am not taking out the wall no, just taking the plaster off because its kind of weak and it comes off quite easily, done in the 80s i think, and i want to tile the wall. was going to tile over it but after reading things on here im a bit scared now!
personally I'd advise against it, too flimsy imo, better using the 12.5mm, have you factored in the weight of the adhesive and grout per m2 too? (typically about an extra 4kg/m2)the tiles are not going to weigh the full 30kg per sqm, i was just wondering if it would be strong enough to hold the weight. so if i do use the 2x1 is it ok to use the 9mm board?
Reply to STud Wall in the UK Tiling Forum area at TilersForums.com
