sibs
Dave I'm hoping you can help me out again since you have used similar. The plastic washers for these boards.. they are not marmox ones but just bog standard white plastic backerboard washers. They sit on the surface of the board when screwed in tight. Is this correct ie they don't have to sit slightly below the surface of the board do they? Also am I supposed to tape and run a bit of tile adhesive over them as I do the joints?
