I need to set a mosaic onto cement paving slabs for use in a garden, 1.7m circle with square off set. this is a brand new set of slabs. I'll need to level off the surface of the slabs with a layer of cement, the mosaic will be done direct onto the surface and I'll be using 5mm thick marble tiles, roughly 10mm size with 1mm - 2mm gaps.
I was thinking of;
1. Cleaning the surface of the slabs, do I need to prime them?
2. To level off the surface, any particular type of cement?
3. Using Bostik Sticks Like or CT1 as the adhesive then sealing (LTP) and grouting with Mapei exterior grout.
I'm not sure if I'll need to use anything to avoid the surface being too slippery I'll have to see how they finish.
Any comments?
Ta,
I was thinking of;
Any comments?
Ta,
