Discuss Review: Rubi ND180 BL electric tile cutter.. in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Dave
I have been using the new electric tile cutter from Rubi....
I found it very light it weight and can come with a carrying box...
The cutter has water containment tray underneath and is easy to access..
I also combined the rubi CPC2 blade with the ND180 BL and it has no vibration like some cutters can.....
This cutter combined with the CPC2 blade is pefect for porcelain tiles...
It also has a removable guard....simply just untighten the 2 retaining screws and it slips straight out....
This makes it perfect for doing plunge cuts for sockets etc......
This cutter also has a tilting table maiking ideal for mitreing tiles...
So if you are looking for a tile cutter that is a good price range then i would highly recommend this cutter..The Rubi ND180 BL......
so it gets a thumbs up from me......:thumbsup::thumbsup::thumbsup::thumbsup:
Nice one RUBI.......
burncross
Re: Review : Rubi ND180 BL electric tile cutter..
i'm after one with an internal water reservoir to avoid all the mess!?
but looks good, cheers dave:thumbsup:
brian c
whats the price of the cutters Dave?
DHTiling
If you contact tradetiler he will be better to give a guide price....
they retail at about £90 with no box and spare blade...and you can get it with the box you also get 2 standard blades if you buy it with the box.....but the cpc2 is extra.....but well worth it.....:thumbsup:
DavieA
Hi Dave cutter sounds pretty good from your review.:thumbsup:
One question,
Was there any chips out of the cut edge or does it cut the tile cleanly? I only ask because my first cutter the contractor does seem to leave a rough chipped edge after cutting that u couldnt really use for example with trim around a window as youd see the rough edge next to the trim.
DHTiling
If you buy the CPC2 blade then there is no chipping......you can buy the cutter with one blade and no box for around £90.....if you get it with the box you get 2 standard blades extra pennies and the rubi CPC2 is extra on top.....
To check out what it will cost with the cpc2 you can contact dave as i said.....the machine it's self was quiete and smooth to use and the CPC2 makes it damn good machine combo...:thumbsup:
David - Tradetiler
Will get a price on the 2 blade + case version ASAP
David - Tradetiler
240v only
looks like the cased version is aprox £108 + VAT
The Plasplugs Master tiler is excelent value @ £79.50 + VAT good machine too - 110v or 240v
TradeTiler.Ltd Wet Saws
DHTiling
yes but that is with a case dave and 2 blades...how much without the case...
David - Tradetiler
£76 + VAT (Rubi's prices went up for the second time in 5 months on 1st August :disappointed:)
CJ
Question for Dave N
Is the bearing in the ND 200 Repairable? as in.....can it be got at to change? :huh2:
My ND200 is making a horrible noise lately.......sounds like bearings to me:huh2:
Reply to Review: Rubi ND180 BL electric tile cutter.. in the UK Tiling Forum area at TilersForums.com
Apatel
