Movement Joints In General and BS5385
pendleh
Hi there
Would like to tile to BS5385. Anyone know whether it mentions movement joints. Can movement joints be incorporated in walls as well?
Howard:stupid:
Hi Again. I really dont want any disaster jobs when Im tiling. What are the most common failures to avoid. I know weber list problems any they have missed.
Best Wishes
Howard
hi howard..have a read of this it will tell you all you need to know mate....
[DLMURL]http://www.landscapespecification.com/mediastore/FILES/111221.pdf[/DLMURL]
Hi Dan
Really need to buy this BSI!!
Care to elaborate on standard? Its practical implementation.
Howard
Of course it mentions movement joints. 😉
Hi Dan
Any topics in forum devoted to joining the Tile Association
Howard
Hi Dan
Howard
Hi,
Generally speaking for walls don't abut tiles against anything. For domestic use leave at least a spacers width and fill with a decent silicon. The stated size in BS is 6mm but it looks awful. There are other times when a 6mm gap is recommended such as bridging different substrates and 3-4.5m centres vertically and horizontally. Kitchen worktops, internal corners and shower trays are all common areas where people fail to leave any movement joint.
Hi DS Tiling
So for an internal corner BS says you should leave 3mm from the tile to the corner of the wall. Any detailed guides on movement joints appreciated.
Thanks for the help.
I wouldn't get too bogged down with this for domestic tiling. On an internal corner I would leave a gap of a few mm when placing the first wall of tiles into the corner, don't abut the tile into the corner. The second wall forming the corner I would leave a spacers width around 3mm from the other tiled wall and fill the joint with silicon, not grout. Ideally the tiles should be able to slip behind each other if that makes sense. The BS is 6mm, that will have been set for a reason but the aesthetics aren't acceptable to most customers. Have a look around though and see how many corners you see grouted and cracked out. In areas of high expansion and contraction like sun rooms make sure you leave sufficient sized silicon joints relevant to the substrate. Schluter do some preformed movement joints for walls but i rarely use them, hope that is of some use.
Tiling Standards
pendleh,
pendleh,
pendleh,
pendleh,
