Led Driver Help Needed Please
Hi Good day
I have a problem and hope someone can help me or point me in the right direction. I'm a guy who like DIY and bought 10 Led Strip Light the make is
Bridgelux
BXEB-L1190U-40E3000-C-C3
Is the part number
It uses 38.2vdc per strip needs to be run @700ma.
so the wattage comes out to just under 400w for the 10 strips.
My problem is while looking for drivers I get the voltage then I don't get enough amps if I get the amps I don't get the voltage from the same driver and the strips was already delivered. The drivers I get that supply 39.2vdc only supplies 1.2A do I buy alot of those drivers and connect it that way ? Or is there a more efficient way of doing it thank you in advance
Continue reading...
Electrical Advice
Tags Tags
None
SHiNiGAMi,
SHiNiGAMi,
