Guest viewing limit reached
Is this wiring OK to use on chandeliers? (UK based)
  • Thread starter Thread starter sillyphilly
  • Start date Start date
Hello!
Hoping for some advice or help please,
Looking for somewhere that sells this chandelier wiring in a minimum 50/100m coil. Here is the link with specs etc:
www.lampspares.co.uk
Chandelier Wire Brown 1.2mm 1470
Buy the Chandelier Wire Brown 1.2mm PLU1470 from lampspares.co.uk and many more chandelier lighting spares and accessories.
It's massively expensive for what it is, and when asking if they would supply in bulk, they said no and will only do a 10m coil at £10+ each. When needing the blue and brown cable, it works out more than £200 which is extortionate 😳
I have found this supplier who said they sell this wiring which is similar in 300m coils, which is fine. And it is only a fraction of the cost from this supplier. (£150 for 300m and free shipping) please see below for specs and info 😊
Alpha Wire 6712 BR001 Eco Wire 24AWG Brown (305m Reel)
Alpha Wire - 6712 BR001 - Alpha Wire 6712 BR001 Eco Wire 24AWG Brown (305m Reel) - <p>The Eco Wire 6711 24AWG Brown 305m is the latest revolution in Alpha Wire
www.rapidonline.com
www.rapidonline.com
I asked the supplier if this can be used to replace the standard pvc neutral and live wiring normally used within the chandelier arms (not exposed, literally fed inside the Arms) they couldn't answer as they said they did not know enough about rewiring chandeliers etc and the specs needed. So really hoping for any advice and if there's any help with tracking down this "chandelier wiring" for cheaper in a bulk quantity 🙏🙏🙏🙏🙏 or if the wiring above would do the job?
Thank you!!!
(we have a ton of wiring on old lighting and our last electrician really struggled with wiring the Arms and the tights spaces in them, he recommended buying this much smaller chandelier wiring, but kind off want to see if we can get it cheaper or advice) 😊🙏
Electrical Advice
Tags Tags
None
UK Tiling Forum; UK
sillyphilly,
sillyphilly,
