Guest viewing is limited
Help with wiring of relay for automotive spot lights
  • Thread starter Thread starter MasterB1aster
  • Start date Start date
Hi brains trust,
I am aware of typical wiring and legalities hence the questions.
Looking for a wiring diagram to allow me to use a dual switch (OEM style for Y62) which features a single input feeding two independently switched outputs for my spotties and drl’s.
I want the DRL’s separate to park and high beam lights as they will be behind the grill and I would like the option for on and off.
Typically your single switch for each will work no problem, but with the single input using the normal input being high beam I would only be able to use the drl’s when the highs are active.
I have been told that I can use accessories as the trigger for both circuits (DRL will be fine with that) I just need to work out how to wire/setup the relay for the spotties from high possibly with negative switching or other methods.
If I could use 2 switches and keep them separate I would but just don’t have the available realestate without cutting into the fascia (which I really don’t want to do)
That is the conundrum…
Any help or preferred diagram would be greatly appreciated.
Electrical Advice
Tags Tags
None
MasterB1aster,
MasterB1aster,
