Currently reading:
Help for Brick style pattern needed
Discuss Help for Brick style pattern needed in the UK Tiling Forum area at TilersForums.com.
Jimmy Boy
Any tips on gauging out a ensuite bathroom for a brick style pattern please. Worked out tile amount for Woman, she gets tiles on Tuesday ready for me to get cracking. Today she phoned and has asked me to fix them brick pattern.
I Never worked out walls for this pattern before.
What's the best method for gauging out for the cuts, sills, door frame and internal corner cuts. And would you use a staff?
Thanx Jimbo
G
grumpygrouter
I have just done a brick bond set. It is straightforward to set out really. Just do as you would normally do then set out again from your 1/2 tile position and re-check your cuts. Really important that you avoid lipping! Makes sure walls are as flat as possible otherwise you will be back buttering a lot of the time!
It does take longer as well as making sure you have your vertical grout lines in line is more time consuming. 1 time I think a laser level is really useful. I didn't have one and it would have helped with each first tile on each row.
Grumpy
Jimmy Boy
Thanks chaps.
Done her working out this morning with tile that was one of a few take home single testers.
One other thing. When you meet the internal corner with a 1/3rd or 1/4 of a tile I take it you would match it up with a longer cut tile on adjoining wall i.e one of the 3/4 or 2/3rd cut tile.
Thanx
Forum comes in real handy yet again.
I got some before pics on my phone will try and match em up with some after pics and post em all up.
G
grumpygrouter
Thanks chaps.
Thanx
Spot on Jimmy, it is important to continue the pattern around the room (as much as possible) gives a much better finished effect.
Quickdraw, lipping is when 1 tiles does not sit flush with the adjacent tile, it sits proud.:thumbsup:
Grumpy
Grumpy
Reply to Help for Brick style pattern needed in the UK Tiling Forum area at TilersForums.com
