Discuss Hand made terracotta in the UK Tiling Forum area at TilersForums.com.
TMTservices
Hi all.
Unsure of a quote and wondering if you guys can help?
Tile; 200 x 200mm handmade terracotta. Unsealed, porous as hell. Rough around edges 25 mm thick.
Sub;
Perfectly flat practically square 12m2 new screed over heating pipes.
Pattern;
Full tile frame around perimeter. Inner to be on a 45.
Your thoughts.
Also how much sealer do you think theyre gonna soak up? Kilos of grout?
The backs of tile are quite bevelled so more addy need.
Labour price only .
Thanks.
Sean.
Perry
what terracotta are they and where are they from ?
TMTservices
Not sure of either of your questions.
Went an took a look today but customer was not there to ask.
Ive taken a photo ill see if i can post it.
Perry
every type terracotta tile are different like a Mexican carillo which you canot use boiled linsed oil on and a french reclaime which you have to thin the oil down with white sprit
TMTservices
how do add a photo anyone?? trying the 'insert image ' but its not having it!!
Perry
difficult to tell from the one tile looks like a Spanish hand made but not from one of the normal factory's have you asked where they are from ?
Perry
i would of thought it would be a day for fixing day for grouting and sealing having to pop back and forwards hope its local job i would of thought plus materials like 2 bags of sticky plus sealer i always use sand & cement with admix on a heated floor
TMTservices
Thanks for that!
So which sealer would you reccomend. Been advised boiled linseed?
Was planning on pre sealing them, fixing, sealing, grouting and a final good cleaning and sealing.
What's your ratio for sand , cement and admix? Are regular flexible grouts no good? Ie bal superflex?
Would the weber set SPF, the slow drying gear be a good addy for these?
Thanks pal.
Sean.
Reply to Hand made terracotta in the UK Tiling Forum area at TilersForums.com
