Discuss Foam layer under joists... in the UK Tiling Forum area at TilersForums.com.
R
Rab78
Hi there I have started tiling onto chipboard and I'm using dunlop flexible set fast plus with flexable additive for added flexablity. Now I have tested most of the floor for movement and the client has hired a joiner to take care of the major parts with too much movement.
There is an overall problem, the joists have a 10mm layer of foam, perhaps used to sound proof the joists from making noise to the neighbours below. Now the foam give a bit, say 2mm or so when pressed directly from the joist.
The job is 112sqr mtrs of offset tiling, ceramic 50*50 with 4"*4" mosaic offsetting at the corner of each tile.
My main question is, although im flexing everything up material wise, will this suffice for such a large area and 'hard to tell' movement?
Assuming that there is 1mm of movement all of the time after the job, should flexable adhesive and grout be good enough?
The other option is the more expensive one, using 2part flexi/liquid mixture and beleive me it costs more than the tiles, even when discounted.
So, please help if you can because the job is on hold until I have confidence.
Thanks in adv. Rab78
R
Rab78
The customer wants it done without any need to board over or re-board as its too much work, too much mess and too expensive. I'm sure the chipboard would do if it was secure enough, am I wrong in thinking along this line and should I now after putting say about 16mtrs down should I now just abandon the job?
I say this because I am trying to save money and still achieve a decent result.
There must be someone who has been in this situation before?
G
GazTech
I support the products in the Dunlop range, this product already has flexibility, and shouldn't have any additional put with it, and this is definately not recommended straight onto chipboard. The only guarantee you have with our product is with the 2 part flexi....Gaz
Adhesion Products
2-Part Rapidset Flex
• Sets In 3 Hours
• Highly Flexible
• Water-Resistant
• Fixes Most Tiles
• Fixes To Most Floor Backgrounds
• For Floor Tiling Only
• Easy-To-Use 2-Part Kit
Ideal Kit For Most Tile Types And Most Floor Backgrounds
Download Material Safety Data Sheet
(Liquid)
(Powder)
Download Technical Data Sheet
R
Rab78
Well, im going to bond the chipboard, neat with dunlop bonding agent. Then mixing flexi additive with setfast plus (flexible porcelbond tech sets in 3 hours), I'm also having the joists supported with screwed in wedges to counter for any obvious movement. Also extra support to bridge gaps in the joists.
This seems the only road that i can go down for the customers benefit and I have given a lifetime guarantee so that the onice is really on me. but then I'll learn from this.
If anyone can provide extra support for this issue then please let me know.
Regards, Rab78.
G
GazTech
Rab, if you continue with this work using the Dunlop set fast plus adhesive, no matter what extra additives or floor primers or floor strengthening measures you put into place, you will still have no guarantee from us. We can't endorse this product for this purpose without a plywood overlay. Failure will be entirely down to yourself. I have a duty as support technician for Dunlop adhesives to advise you to avert disaster, eliminate the risk please just switch product and swallow the cost difference now, ....Gaz
R
Rab78
Yeh I want to switch , just finished the 2nd sitting room a bit of an unused room in the house, well not used frequently, I can always switch to two part flexi rapid for main areas like the hallway, kitchen and main sitting area.
Thanks for the concern and I will keep you up to date on any adverse effects. Like I say I will monitor this even when the job is complete.
R
Rab78
The job is done , has been down for 2 months now, no cracking, minor grout cracking in one area only, I used dunlop tile on wood after priming the t+g floors with undiluted bonding agent. Tile on wood is flexable and suitable for t+g, a bit messy but worth the money £21/3mtr coverage. Expensive for a big job like this, but worth it.
I will be going back to the job within 4 months for a re-examination.
R
Rab78
Reply to Foam layer under joists... in the UK Tiling Forum area at TilersForums.com
