Discuss Cutting sqaure 'holes' in porcelain in the UK Tiling Forum area at TilersForums.com.
Deleted member 1779
I'd mark the FRONT of the tile
Drill out the corners to be safe:
Drill out the holes front to back
Then plunge cut the lines on a small wetsaw
looking through the holes of the tiles to see where I am cutting
That way you're guaranteed not to have any over runs.
Ignore the fact the demo is on a tiny tile.
If you have large porcelain tiles like this then doing everything from the front leaves less room for error.
Mistakes on BIG tiles are costly.. Drilling out sockets can be tricky
Results.. A socket in a tile
I
Italy
I also like this, then use blade grinder with 75mm Montolit from above without touching the corners , no breaks google translated
New posts
Reply to Cutting sqaure 'holes' in porcelain in the UK Tiling Forum area at TilersForums.com
  • Sticky
