Discuss Correct substrate for longevity and waterproofing! in the The Welcome Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Ash786
Hi I’m doing my own bathroom after many years of neglect, I know guilty as charged but I’m on the pursuit of a makeover that will make it good hopefully for many more years to come but I need some help in this and I’ve discovered this forum. Thank you all for having a platform that can share for a DIYER like me! 👍🏽🙏🏽
I’ve been dismantling all the tiles and have discovered the whole room has been majestically plastered with pink bonding. All the bond on the window side where the bathtub is has literally soaked into the brickwork and I have had to do away with it. The other side isn’t that bad being All of drywall material it also has gone very powdery and loose.
I was going to take this back to brick work then point the bricks. Then render and after 2 weeks of curing time use KA Slurry. Then tile over, is this method wrong or right in this situation. Can someone tell me the correct procedure as looking at the damp soaked bonding it was only a matter of time before the brickwork would be obsolete!
You’re concise help in this matter would be appreciated immensely! That’s an old photo I took all the old stuff and it just brickwork now. :oops:
Dumbo
Look at fixing jackoboard or wedi board direct to brickwork but you need it to dry first .
Dumbo
No , waterproofing and build up in one go and no waiting for render to dry.
Reply to Correct substrate for longevity and waterproofing! in the The Welcome Forum area at TilersForums.com
Finias Coroama
