Can't figure this out
Hi, first time here so hopefully not a silly question. I am tiling a bathroom for the first time with 1200mm x 600mm porcelain tiles horizontally and a room height of 2445mm, 5x 2mm grout lines
Using 4 full tiles I am left with 37 mm sliver cut.
Cutting the tile with one piece on the bottom at 300mm and one on top 337 or so would add considerable expense.
I would consider dropping the ceiling if this is not a ridiculous suggestion
Dose anyone have a better idea or advice
Yes cross batten the ceiling with 2x1 roofing batten, then 12.5 plasterboard and skim- you’ll be there.
Check first for level and run offs, use CLS (38mm) instead of batten if levels are off as this will give you another 15mm of leeway overall.
DIY Tiling Forum
Tags Tags
out this
Trevor101,
Ben-gee,
Trevor101,
Ben-gee,
