Currently reading:
backer boards
Discuss backer boards in the UK Tiling Forum area at TilersForums.com.
Mel
Hi, I'm new to the forum and this is my first posting.
I am about to tile my kitchen which has a chipboard floor. Am I right in thinking i need to lay backer boards down first before laying tiles. If so, is 6mm a satisfactory depth of board to buy. Would tile cement be the way to secure them to the chipboard. None of the DIY stores appear to offer these backer boards, which leave me questioning whether they are needed. Any advice welcome
Time's Ran Out
:welcome: Mel. Before you buy any materials, first establish the construction of the floor. Check that the chipboard flooring is nailed to joists, what size are they and at what centres. Make sure you have no deflection and over what is the total area you are planning to fix tiles for weights. These items will ascertain how much strengthening of the floor will be required in preparation.
Reply to backer boards in the UK Tiling Forum area at TilersForums.com
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
