Discuss Are 15 mm to 20 mm gaps too big!! in the UK Tiling Forum area at TilersForums.com.
chorltonred11
Hi
I'm new to the forum and i have to attempted my 1st tile job. Any way all well until someone pointed out the gap betwee the tiles was too big! I used ceramic tiles on my kitchen floor and when using the tiles spacers i postioned them incorrectly. The gaps are around 15 mm!! Is this too big and will it cause me problems if i grout the gaps in future or if it is ok what type of grout will i need to use. I have not finshed laying all the tiles yet and have been using ready mixed wickes floor and adhesive grout for concrete floors. Can someone please help me!!!!!!!!
Sorry if i have posted this twice as i'm new forums as well!
grumpygrouter
Sorry to be the bringer of bad news but ready mixed adhesive really isn't suitable for floors, no matter what the diy sheds tell you. What size tiles have you laid? The adhesive you have used need to to dry by evaporation and not chemical reaction. if you have laid large format tiles, there is a chance that the adhesive will never dry out at all. As for the grout, well this can be got around by using an appropriate wide joint grout but I feel you need to address the adhesive issue first. Good chance you can still lift your tiles and start again with a more appropriate adhesive and get your grout joints down to a better size.
TheWrightTiler
sorry mate but have to agree with grumpy there
ready mixed adhesive on a floor regardless of the substrate is in my opinion a waste of time and money
powdered adhesives are the only way to go as grumpy says ready mixed is a dispersion adhesive which dries by air and powdered adhesives dry chemically
where are you based
if near a ctd or tile giant get a bag of mapei kerraquik, each bag will cover roughly 5m2, mix a little at a time if unsure on speed
floor must be primed also using a suitable accrylic primer not pva
as for the joint widths in my humble opinion 15 - 20 mm is too big, normally 5mm is sufficient but can do up or down depending on style
again the tile shops i listed can supply a suitable grout for this purpose
sorry mate but as the song goes rip it up and start again
andy
ps welcome to the forums
chorltonred11
I lifted two yesterday and they came up pretty easily. The outside adhesive was dry but inner bits still damp. I will lift the rest sat morning and start again with a smaller gap!! What should i use to prime the floor and how long before i can lay tiles on it. Also what type of powder adhesive and grout should i use and where can i get it from? I'm based in Manchester and have easy acces to Wickes but not sure about ctd or tile gaint. Thanks to everyone for all your help!! Just a quick note though i thought the big gaps looked good and it's no wonder i was thinking i have loads of tiles left!!!
Deleted member 9966
Sorry, just spotted the bit about primer too. All of the top brands - Mapei, BAL etc - do their own primers. If you speak with the shop advisors, they'll be able to recommend one for the floor you're tiling on to. The instructions on the bottles usually tell you how long the primer takes to dry.
When I laid my kitchen floor the BAL primer I used said to wait 30-45 minutes from what I recall. I gave it a good hour or so and it was perfectly dry and tiled no problems.
Deleted member 9966
Yeah, BAL products are very good, and I used these when I did my kitchen floor. Don't forget to go for the powdered, cement based adhesive and it's up to you whether you choose to go for a rapid setting adhesive (takes around 4 hours or so to set) or a standard adhesive which will take substantially longer to set. The rapidset adhesives unfortunately tend to go off quicker so if you're unsure about how fast you'll be able to get the tiles down, I'd go for standard adhesive as it will stay wet in the bucket for longer.
And try and haggle on the prices as speaking from experience, BAL products at Topps are quite expensive if you're a normal Joe Public customer and not a tradesman.
And when you've done your masterpiece floor, take some pics and splash them on here so we can all have a looksie :hurray:
grumpygrouter
I feel such an idoiot!!
Don't! We all learn by mistakes. You will need approx 3 bags of adhesive (20kg bags) as for the grout, that all depends on you grout joint size, depth and dimensions of tiles. Big tiles will use less grout and small tiles will use more. Gives us a few more details and we can help a bit further with this.:thumbsup:
obobsmith
Good advice there, dont get yourself flustered and If you have the time dont use a rapid set addy, that way you will remove the time pressure that a rapid set will place on you and hopefully allow you more time to do it right. Topps own brand addy is good and considerably cheaper than BAL.
Curious as to how you placed the spacers to get 15-20mm grout line:yikes:.
Welcome to the forum.:welcome:
Reply to Are 15 mm to 20 mm gaps too big!! in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this, The property unfortunately flooded throughout. Now although I'm told it's all dry now I'm reluctant...
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
