Discuss Anyone recommend a DECENT cutter? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi, I'm after a manual cutter that cuts 600 by 400 Porcelain like butter! (Price not a problem)
I have just purchased a rubi ts 70 thinking it would be ok, but it struggles with the easiest of cuts and the breaker doesn't have the strength to beak the whole length of the tile,600mm. It cuts the corner edge off the tile even on simple thick straight cuts most times? I end up scoring the tile then using my wet cutter to finish the cut. This is making my jobs turn into marathons !! not too mention the wastage.
I have three manual Sigmas but prefer the Klick Klock, just my preference...
I'm looking at sigmas but not sure which one is best as theres loads...
Do you know any tilers that own one...
I would say go for a Sigma for all round performance.
If its to go through porcelain like butter then I would look at a Tomecanic SuperCoup 75.
I bought 1 a while back & it's a beast of a cutter but it hardly gets used since I went to Sigma.
Only suitable for porcs though as its too brutal for glazed ceramics..
Don't know any tillers with one, I was informed a rubi ts 70 would be ok! but it's disappointing.
The Rubi tx range is the only model Rubi do that's capable of dealing with porcelain.
You can cut porcelain on all the Sigma tile cutters. Just need pick a size and a handle type.
Yeah, just a very light score on ceramics.
Can you recommend one that could cope with 600 tiles and over and handle type?
Do you mean somethink like the Rubi way of cutting....
The most popular cutter is the
3C2M 74cm MAX cutter. Max is a push handle that is easy to use. powerful breaker that will cut up to 20mm porc but at the same time do ceramic, glass, mosaics etc..etc..All our cutters are built from start to finish in Italy by hand so you get what you pay for.
A lot of the time, when cutting Porcelain, it's a technique thing.. My mate can cut Porc on his Rubi 9 times out of 10, yet I'm more like 2 out of 10. I've tried doing it exactly how he does it, but no joy!?!
Hopefully, I'll get to demo some sigma's some day, and something will just click!
Rubi or Sigma.
Reply to Anyone recommend a DECENT cutter? in the Canada area at TilersForums.com
