Acid Marks On Limestone
Which brushes would you recommend if it comes to that please?
I'd probably go with #120 grit as it would be reasonably gentle but still remove some of the surface. If you need something more coarse you can drop down a grit or two. They aren't expensive but you'll need a variable speed grinder or polisher to use it on.
hmtiling,
Dumbo,
hmtiling,
Dumbo,
