Discuss Tile cutter maintenance (montolit) in the Tile Cutters area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all,
I've just bought a montolit minipiuma and noticed the rail is quite stiff.
Does anybody know how to fix this? I don't know whether it needs adjusting or lubricating?
I've never had a montolit before but got a good deal so couldn't let it go!
If it needs lubricating what am I best using on it?
Also any tips on how to work the thing would be helpful as I'm usually a rubi guy!
Thanks in advance!
Hi mate ..If you’ve only got it & it’s stiff it just needs adjustment…there’s 2 small screws on a blue bar on the main handle …don’t make it too loose as it goes wobbly resulting in a wobbly cut…keep it lubed with some WD40 every now & again
Hiya pal, yeah ill try that thanks, is wd-40 alright to use or should it be the silicone version? Some say wd-40 some say silicone spray?
I just use the spray as the dust from working just drys it up …suppose you could use some other sort of lubricant…hope this helps
Reply to Tile cutter maintenance (montolit) in the Tile Cutters area at TilersForums.com
Apatel
