Discuss Do I get chips with that ? in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Filip
Rubi viper from Topps in a 115 mm Milwaukee cordless it's brilliant no chips great on envelope cuts on wet floors !!
All the blades with this kind of diamond design, are good. The blade thickness must not exceed 1, 2mm. You'll see it solves the problem. Price, from £13 to £50, only changes the life of the blade.
Ahh I see thanks chaps, googled the Rubi and it has that pattern also thats great for me that the price only affects the the blade life gives me a chance to buy cheap and use for my one off jobs.
Filip
Other solution if it is ceramic, leave the tile for a few minutes in the water, then make the cut.
I can get away with ceramic because I dont get such bad chips and I can cut to the waste side of the line and then sand down to the line.
Tried sanding down a porcelain but nothing in my DIY tool arsenal would touch it
Reply to Do I get chips with that ? in the Tile Tools | any Country any make any model area at TilersForums.com
laattaana
