Discuss Insulation Boards on Weyrock in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
A
Anon1324
Hi all,
Got my dad's en-suite to tile, planning on laying some electric underfloor heating down and just want verification.
It's a weyrock floor currently. My plan was to lay insulation board (link below) on top of the weyrock, then the UFH with some self levelling compound on top of it, and then floor tiles to finish off.
People I've spoke to have said it needs 3/4" plying before the insulation board - these people aren't tilers so here I am to ask the people in the know.
Do I need ply before my insulation board, or will the insulation board be enough? Surely if I've got to ply it still, the finished floor level is going to be a good 40mm above the carpet in the room adjacent.
Here's the insulation board: Klima Thermal Board Insulation 5 Pack - http://www.NoLinksToThis/p/klima-thermal-board-insulation-5-pack/93806
Thanks,
Mark Frost
Those boards from screwfix seem very expensive for pack of 5. I use 6mm marmox boards or Jackoboards. Screw the boards down straight to the chipboard using 25mm screws with tile board washers. Tape and glue the joints of the boards for added strength. Under floor heating on top then leveling compound no need for ply.
A
Anon1324
Thanks very informative. So I think I had the right idea by the looks of it. Where do you get yours from?
A
Anon1324
Floor will be coming up in part for electrical feed and also first fix of new plumbing so should have a good understanding of what's where under there.
I never ever screw through a floor, unless re fitting a few floor boards or something
A
Anon1324
When I put the self-levelling compound down should I just take it all the way to the wall, or so I need to leave a gap between it and the wall (and fixtures such as shower tray). If I need a gap, what's the best way to achieve this?
Mark Frost
Not to the shower tray no, but around the walls apply some expanding foam or silicone just to fill in any gaps to stop the SLC from leaking to downstairs. At the door wedge a bit if wood to stop the SLC from leaving the room.
Reply to Insulation Boards on Weyrock in the Tiling on Underfloor Heating area at TilersForums.com
hoponbaby
