Currently reading:
Access Panel
Discuss Access Panel in the DIY Tiling Forum area at TilersForums.com.
scotmk
I am very please with my access panel. Took me as long as it took to do a whole wall, but not bad at a all lol.
scotmk
The panel is a door from b n q then I have cement boarded it then tiled it with edging.
The tiles are not from homebase, they are from our local tiling/bathroom place.
The plug socket is only 3 amp and it's going inside a cupboard for the under cabinet lights, my electrical man said it's classed as another room as its in cupboard and the planning guy has signed it off ok.
I have 1 box of each tile spare.
I covered the gap already in another post, going to be grouted then masked and painted to match ceiling so it blends and vanishes.
scotmk
Looks a good effort and I hope you've enjoyed it so far.
That exterior trim corner on the bath looks a bit sharp - I tend to bend the trim around.
Thanks, been a big job, just finished now big clean up before start grouting on mo day.
That trim looks wise than it is still got the film on it and it's peeling at the top lol. The shower screen is coming over near this so will be covered
scotmk
I started off with a 10mm trowel, but the walls were not as straight as should be also there was a difference in thickness from the backer board to plasterboard areas and the partition wall not 100% 90° to the wall. So have dot n dabbed a lot,have used a good amount of dot n dab, not just a little on each corner, have used as much as would have been trowel on,they are solid not gonna come off.
The big walls needed to be straight as having fitted units along 2 of the walls both base and wall.
Reply to Access Panel in the DIY Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
Hello, after watching so many instructional videos and planing, I just can't understand how to tile a simple drywall construction in our bathroom. I got some good advice here so I hope you guys...
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber floor in our barn conversion. The area is large, 21m x 8m. Having spoken to various UFH suppliers I...
