Discuss Access Panel in the DIY Tiling Forum area at TilersForums.com.
scotmk
I started off with a 10mm trowel, but the walls were not as straight as should be also there was a difference in thickness from the backer board to plasterboard areas and the partition wall not 100% 90° to the wall. So have dot n dabbed a lot,have used a good amount of dot n dab, not just a little on each corner, have used as much as would have been trowel on,they are solid not gonna come off.
The big walls needed to be straight as having fitted units along 2 of the walls both base and wall.
Reply to Access Panel in the DIY Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
  • Sticky
Hi All, We are looking for a tiler for potential tiling work in the Suffolk and Essex area. We...
