Discuss Granfix Grey Grout Dried Different Colours in the Australia Tiling Forum area at TilersForums.com.
AliGage
Subscribed
1,138
Peterborough, England
Ok (bites tongue)......
Your grouting is clearly efflorescence. You've used far too much water to wash down. You can see where water has been left within the joint, particularly on the corners.
Charcoal I find is one of the most sensitive colours to this. Would of been an advantage, so something to do in the future, after your last mop run over with a soft cloth to remove any excess water. Then once dry buff to remove any remaining grout residue.
Floor tiling: 6mm is no good for any tile on the floor IMO. What tiles are you fixing?
Depending on how good and flat your surface is you could possibly use an 8mm but generally speaking a 10mm notch is used.
138
Bolton
Thankyou. I appreciate it must be very frustrating when basic type questions are asked, but as most people i don' t like making mistakes or a bad job. I have and i am learning all the time and the grouting finish is the first time this has happened to me. Thanks
Tile Shop
Can't tell very well from the pics, but can you confirm the size of the tile and whether it is ceramic or porcelain?
Dave
Subscribed
1,000,000
Co.Durham
Ok thanks. I did leave for couple days. I have another question, is there a minimum bed thickness for floor tiles to stop height being raised too much. They are going on to hardie backer
They depends how thick you used it and the tile size.
As for the floor , minimum bed depth will be on the bag ,
138
Bolton
I thought it would be good to end this thread on a positive note. Floor went down well on hardie backer boards and really impressed with the stability of these. Thanks to all with advice. Used a "normal" floor trowel and height of floor acceptable. The bathroom looks good and customer happy after all. I'm working on perfection and nothing less, maybe one day i will be giving others advice who seek help. Thanks to all
Glad it worked out for you @Ivan Rubery
Did u sort the grout problem, I know u said u had to change the colour.
Did u?
Andy Allen
1,318
Gloucester
Well effervescence is gas bubbles in a liquid haha :D sorry Steve couldn't help it! :(
Efflorescence is the formation of salt crystals after water carrying these salts evaporates.
Most common cause is over washing with a sponge that is saturated with water or standing water in the joints.
If it's light and dark grey it could well be efflorescence.
Grey grout is dark when wet, efflorescence would turn it light grey.
How long has it been since u've grouted?
Or has the area been subject to premature heavy wetting?
Or is room very humid?
Or even grouting too early I'd addy hasn't set properly.
These can cause efflorescence
(derived from Latin word meaning "To Bloom") :rolleyes:
U can generally remove it with a Phosphoric acid based tile and grout cleaner.
Obviously test small descreet area first.
Spot the nerdy kid......lol
Reply to Granfix Grey Grout Dried Different Colours in the Australia Tiling Forum area at TilersForums.com
