Discuss Riven slate skirtings in the Canada Tile Advice area at TilersForums.com.
Ian
I hope you can see the photos clearly enough to help. I'm fitting a floor in there porcelanosa slate tiles next week and am doing 150mm skirtings, the customer wanted to use black metal trim bit I talked them out of that. Question is, what is the best way to finish them? Too uneven to profile (I think, haven't tried), maybe just polish the edge? Not sure.
ImageUploadedByTapatalk1364577675.926360.jpg ImageUploadedByTapatalk1364577698.893719.jpg ImageUploadedByTapatalk1364577717.026912.jpg
The Legend; Phil Hobson RIP
That looks spot on Phil. Did you do anything with the exposed edges? Hard to see from pics. (other than sealing them)
No Bri just grouted the top edge joints very carefully after sealing it then sealed again. I used decorators caulk on the joint between the skirt tile and the wall, if that makes sense, the customer wanted a natural look on the 100mm skirting, no trim.:thumbsup:
Reply to Riven slate skirtings in the Canada Tile Advice area at TilersForums.com
