Discuss Dewalt D24000, Rubi DW250N or Rubi DW250NL in the UK Tiling Forum area at TilersForums.com.
R
richiep
Hello all, looking at spending out on my first wet saw and want to buy once as they cost a fortune!! The dewalt seems to get high opinions from most on here, but is the pushing of the tile on the dewalt preferable to the pull of the saw on the rubi? And out of the 2 rubis i mention above, am i best to plug for the extra long version to accomodate longer tiles to save buying another saw down the line? And are these rubis a good buy too?:mad2:
Gazzer
Having owned both a Rubi and now the DW24000 i would say that the Dewalt wins almost everytime from quality to ease of use.
The only time the DW24000 would lose out is cutting half way through a long tile as the arm holding the motor and wheel is about 34cm away from the wheel itself which gives limitations.
Overall the DeWalt is in a class of its own for the price.
Main issues with my Rubi were its inaccuracies when cutting. The quality was very poor too with the rubber bed matting coming off within days of using it and paint flaking off the metal tray which was prone to rust.
R
richiep
Thanks for the info, was the rubi saw you had one of the ones i mention above? Would you say that i wouldn't get the use out of the larger rubi for larger tiles? I just don't want to settle for a saw and find myself having to get another one to cut larger format tiles that about 1000mm. What do you do for tiles of that size?
Gazzer
It will all depend on "what size" tiles you cut. Its no good saying you only cut/ use 33cm tiles so buy a machine that has a max cutting size of 40cm only to find that your next job is with 60cm tiles.
You may buy a Rubi that will cut 100cm tiles and low and behold someone comes up with bigger tiles :mad2:
For my type of market i find a machine that has a capacity of 60cm is fine....but that for me.
And Yes the Rubi i had was a DW250N.
R
richiep
Thanks, seems you recommend the dewalt quite highly, i have read a lot about it and does seem to be a good saw, i thought it might be better to get a saw where the tile kept still and the saw moved, maybe not then. Thanks for your help SirRamic
Reply to Dewalt D24000, Rubi DW250N or Rubi DW250NL in the UK Tiling Forum area at TilersForums.com
