Discuss Hardibacker laid with no adhesive. in the UK Tiling Forum area at TilersForums.com.
Sean Kelly
1,068
Ruislip
The chipboard is flat, has no deflection and is in a kitchen. It covers approx 11sqm.
A Hardibacker rep as stated that Hardibacker boards can be laid directly onto 18mm chipboard and screwed down. If the chipboard is flat there is no need to use addy.
Is the above true?
Also, I’ll be using Fastflex next week. I have told the customer I have to buy a special solid bed tipped trowel for spreading Fastflex so I added £20 to the estimate. They came back and said they will not pay for it. It’s ok to use a 10MM half round trowel for laying 500x500 tiles?
Cheers
Sean
White Room
I've never used hardie on the floor without any adhesive between the two surfaces, I'd be back skimming the tiles, use your trowel and lift a tile and check the coveradge, if your not getting good coveradge use a bigger trowel
kilty55
1,113
edinburgh
i wouldnt highlight to the customer tool prices in your quote it just gives them the chance to say im not paying for that.just add it in your price:thumbsup:
david campbell
if the chipboard has minimal movement then it should be fine to screw down,why not go to less expense and use ply or is there a height issue?
don't think i would ever bill a customer for a trowel though,they are your expenses and can be re-claimed in your tax returns,if the floor is good for level then a 10mm u-notch should be fine!
Sean Kelly
1,068
Ruislip
David, the kitchen is in (and sitting on the chipboard). Adding the thickness of ply, addy & tile would make too much of a step up from the hallway.
Take your point about the trowel, I only added it because this customer is paying a lot of money on materials for a good job. The chance of some other future customer opting for Fastflex (the expensive option) would be pretty slim. Cheers for your advice. Sean
Sean Kelly
1,068
Ruislip
Not a floating floor is it..?
It's a long long story involving BAL Tech, Topps Tiles, Hardibacker and of course the customer, oh......and another tiler......and me.......and tilersforums. I've got another thread about this, but to answer your question I do not think it's floating. It's pretty ridgid and has virtually no deflection. I am going to overlay it with 6mm Hardi and use Fastflex. Cheers Sean
R
Rob Z
Hi Sean,
FWIW, one of my friends in the tile business is an inspector and consultant, and sees installation problems on the national level in the US and Canada. He says that backer boards installed w/o thinset underneath (as per manufacturer instructions) comprise a huge number or job failures, and are in the "Top Five" list of calls that are received at the TCNA (Tile Council of North America).
Unless there is something different about floor framing and Hardi in the UK, I wouldn't install Hardi without the mortar underneath it to give it full support.
DHTiling
You not sure..? Are there any fixings in the floor..?
Reply to Hardibacker laid with no adhesive. in the UK Tiling Forum area at TilersForums.com
