ooooopppppppsssss!!!!!!!
made a bit of a mistake on the tiling that i was doing so well at, its for the brother in law. looked all over and looked spot on. but on further inspection ie photos i took noticed this balls up. what do you suggest, take a chance and leave it or take it off. if the latter how do i go about it
cheers a peed off ian
Easily done ian...... ...you will know next time.....if you can get the border out and have a spare.. change it..
Ian m8.its not very noticeable but i can see it on the border that you have put the dark colour against the dark colour.If you really wanted to you could take it out no probs and scrape out all bits,prime and insert another border.:thumbsup:just be careful if you take the border tile out and use a small chisel and hammer.:thumbsup:
have I missed something connor? are base tiles on brick bond, oh yes,on the mozzy,which is the shortest length to a corner? I'm guessing that the other borders are following the one that is upside down, so it might be a strip out to the corner. Must admit I didn't see it at first, was to busy trying to see if base tiles were bb
i have made a decision and am going to leave it. they will have spares over and if they notice it i will replace it. being a bit mean here but we have over run by about a day and a half already because we had to strip off all the old wallpaper and the junk in the loft had to be moved which they promised they would do. if i can get away with it super duper, might even be able to get the towel radiator to cover it..... IF THERE IS ONLY ONE WRONG????????????????????????????????????????
Tags Tags
usa
connors12345,
AllurePTS,
connors12345,
AllurePTS,
