Discuss Weight limits in the Canada Tile Advice area at TilersForums.com.
CJ
Points
1,088
Somerset
Wall Substrates Maximum Weight of Tiling per m²
Gypsum Plaster........................................................20Kg/m²
Gypsum Plasterboard Direct (without a plaster skim)....32Kg/m²
Plywood (WBP) Up to............................................30Kg/m²
Lightweight Tilebacking Boards* Up to 40Kg/m². (Dependant upon the type and thickness of the board)
Glass reinforced Cement Sheets Up to 50kg/m², (Dependant upon the type and thickness of the board)
Gypsum Fibre boards Approximately...........................35- 40Kg/m²
afright
Points
1,013
Broadstairs,Kent.
Just had a look at job, 600x600 porcs on skimmed plasterboard , curved bath panel made from 6mm ply and a floating chipboard floor I think I,ll give that one a miss.
Reply to Weight limits in the Canada Tile Advice area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
