Stone repair kit recommendations
On one
I need to make a minor repair to a chipped Limestone tile,has anyone used one before,Good or bad?
Dust from the stone being used mixed with super glue and used very quickly for minor repairs works for me. Then polished in with Silicon carbide pads.
Not used specific kits apart from one that was given with some moulded stone wall cappings I fitted. And all that was was some white cement and white sand. Effective tho.
As 3_fall says, grind some dust from an off cut and mix with clear resin, it matches perfectly in a way you can never reproduce with coloured resins.
Never thought of that one! even though I have done it for filler for joinery work(sawdust and PVA)
I assume superglue is fine on stone?
Before and after shot for the forum will win you brownie points and a pint.
On one,
On one,
