Discuss Silicone in the Australia Tiling Forum area at TilersForums.com.
F
Flintstone
I've purchased a fugi kit to try out after reading about them on here, I've always been a finger and washing up liquid man and I make a good job, but, with a job coming up that requires black silicone and white tiles, I thought it might be worth a try with this kit. Question is, how do you lubricate the tool? Spray something on the silicone?
F
Flintstone
I mean, I normally put my finger in the washing up liquid and water and smooth it. Do you dip the tool in, or spray it on the silicone instead
P
p4ulo
Mix up a water / washing up liquid solution in a squeezy bottle and spray the silicone and go onto it.....it works. I must admit, before I did that, I did run along it quickly with a licked finger to push the sealant into all edges and get it stuck fast.....
I
Italy
I need some silicone lesson.
I'm not very enabled with silicone.
I do very little, but every time I do I problem ...
I will study on TF :)
John Benton
1,138
Leeds
It take a bit of practice, best way is to make some internal corners, especially 3 joint corners, with cuts of left over tiles. You need to make sure you don't use too much silicon otherwise it starts getting messy.
It does take time but the finish you get is superior
First pic I had to use masking tape and the old finger as it was just not feasible to use the Fugi tool because of the relief of the wall tile
Reply to Silicone in the Australia Tiling Forum area at TilersForums.com
  • Sticky
