Z
zygo
As some of you will know, I'm doing a DIY project to tile the floor of a garage conversion with granite tiles.
I have now acquired a used Rexon RTC200a radial saw. I've never used one before and there's no manual with it but it looks pretty easy - add water to the reservoir, turn it on and go.
Anything else I should know? Is there anything in the manual i should be aware of. If someone has a manual and can make a pdf of it, please PM me with details.
It seems to have the original wheel in it, which apparently was good enough for porcelain so I shall try it on a few granite offcuts. If I can, I hope to get away with that but 10mm granite is hard and I realise I might need to spend a bit on a better one by Marcrist or Rubi.
Thanks to all.
Z
Thanks to all.
Z
