Preparing a window recess for tiling
robbieee
So my window currently has a frame around it. It is just a matter of ripping this wood out and plasterboarding? I want to tile all the way in.
There is a space inbetween the inside frame and the wall. Is this cold bridging? Do i need to keep this when installing the plasterboard?
quite hard to answer without knowing type of house, lintels used and window type.
If you suffer from what looks like condensation it could be down to cold bridging.
Had a victorian house that suffered from cold bridging.
If you don't have any damp around your window then the likley hood is that you dont suffer from it.
so i would fill with expanding foam cut back then tile.
Like i say hard to know exactly what you mean, but cold bridging is the problem created by warm houses, cold external temperatures and inadequate ventalation.
In older properties a gap between the lintel and the internal wall was used to prevent this from happening.
Hope this helps.
robbieee,
thompsonbrown,
robbieee,
thompsonbrown,
