Discuss How to check deflection on plywood across joists in the UK Tiling Forum area at TilersForums.com.
jesteh
Time and time again, I see advice offered to check for deflection before starting to tile on floorboards/plywood across joists.
What I don't understand is - how do you check for deflection and how much deflection is acceptable? Is there a gadget or a certain way of doing it? Do you jump up and down looking for a bit of trampoline bounce. Do you use a spirit level and see if weight causes it to bend? Any other ideas?
C
Colour Republic
it's a bit like cooking a steak... you kinda just know by feel. Others sometimes place a glass of water on the floor and see how it reacts when stomping round the room
jesteh
I have tried the water test but even with 25mm ply, there are ripples in water when I bounce next to it. (I have too much time on my hands).
C
charlie1
Look at the floor as you apply pressure, there should be next to no visual movment.
steve187
use a long straight edge/level and stand in the centre, next to the level, and see if there is a gap between the level and the floor, get a friend/wife to help as well, or place some weight in the centre.
As colour republic posted you kind of get a feel for it.
C
craigdon
Most floors I come across, until I've preped them, have a gap under a straight edge lol!
C
Ct Ceramic
[DLMURL]http://www.proconweb.com/pdfs/publications/technical_articles/deflection_-_are_current_standards_realistic_2001.pdf[/DLMURL]
With a litle knowledge you soon understand that nearly all floors you tile on that are wooden have too much deflection.
Reply to How to check deflection on plywood across joists in the UK Tiling Forum area at TilersForums.com
