Carl Morrison
I've been using this forum a lot in prep for tiling my master ensuite and a wealth of knowledge here... I have some questions specific to my job though and any help/advise appreciated
I am using 10mm 600x400mm porcelain tiles with minimal back details
Maybe 1mm depth. Tiling on to mix of new plaster board (no plaster skim), cement backer board for wet area, and ply flooring levelled with level flex. Proposing to use standard setaflex on all surfaces (appropriately primed)
1) please advise trowel spec/sizefor each substrate
2) I'm thinking of buying Erbauer ERB337TCB 750W Tile Saw 230V | NoLinksToThis. Gets good reviews but wondering if anyone here has used one?
3)Do you guys use tile trims for external corners or mitre the tiles? If mitre, can you advise method/tips please.
4) anyone used level flex? Is it really self levelling or do you need to work it?...and the manufacturer says OK to 3mm but has anyone tried to feather to less?
5) I have a first generation big clinker...do you think this will handle straight cuts on these tiles OK?...length or crossways? Its long enough just not sure how it will cope with 10mm porcelain?..
Thanks in advance
Thanks in advance
