looking for some advice , need to buy a plunge saw for large format tiles
must be 110 v , also will need the guide rail
whats your thoughts on best out there
looked at the rubi tc 180 but apparently don't do 110v
like the look of the festool but cant find 100v
I have the Makita SP6000 in 110v, 5 years old no problems and in constant use. Not tried it on tiles before but makes easy work of Minerva work surfaces.
Makita make a battery version but not sure if it would last cutting hard surfaces like tiles.
You're going to find most of these carpentry plunge saws at 160mm blade diameter. They are marketed in the UK as carpentry tools and that's the extent of their guarantee within the UK. Festool however sell the TS55 in Germany as a Stone masonry tool.
If you want something with more power that can also cut wet take a look at the FLEX CS60 wet which is now available at 110v.
One thing to bear in mind with all these type of saw is they cut on the upstroke, unlike a wet tile saw which cut down through the surface of the tile.
This can sometimes create issues with breakout and chipping. Water feeds reduce this or cutting the piece upside down.
Find the cheapest price for both professional and DIY wall and floor tiling tools
in the UK. Brands such as Rubi, Genesis, Fein, Karl Dahm, isomat, Schluter, Tilemaster
and more.
