Discuss Free Original Style Display and Other like New Displays- Tile Donkeys in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Stonebro2
Have lots of unusal display stuff - Travertine Columns - Egyptian Hieroglyphic Freeze 90 x 50cm, Mosaic Topped Tables, Green Granite Tabletop suitable for use outside etc. Room Lots of Stone - all to be cleared by 31/10/2012. Please read and pass on - I would like small monies for items I am Selling - all stands are free have some large tile display stands enough to fill a showroom all FREE Most are like knew 1 a bit battered - Large corner display Cost £3000 - £1000 from factory £1000 Distributor and £1000 from us - FREE Like NEW very modern - Will Post pics of displays. We had a lovely showroom - but having FibroMyalgia and going blind and other health problems its time to stop. ADMIN hopefully not breaking any rules here just don't like kit going to waste!!!
Having just closed a Tile Showroom, I have a quantity of Original Style display stands, if you are an existing seller of Original Stayle Tiles you may have them FREE if you come and collect them. If you are an existing customer you will know how much these stands have cost us - A pretty penny, but things are tough out there and I would hate to see them go to waste.
WE NEED THEM COLLECTED BY 31st OCTOBER 2012 NO LEAWAY
We have
Earthworks large stand
Winchester large stand
Winchester samples trays
Winchester Residence tray
40 - 50 Winchester astted boards
4 x fully merchandised MOSAIC stands
2 x Mosaic back to wall stands for Sample Cards
5 x Victorian Floor Boards & Stand
1 x Artworks Stand – Victorian Wall tiles
1 x Glassworks Stand
2 x Glassworks Spalhbacks wall boards
1 x Glassworks sample tray
1 x La Belle Cuisine stand
1 x set Tileworks boards & loose samples
1 x Odyssey Floor tile tand
If you are not currently a customer but the Rep confirms to me you can have an account then all being well you can have them. If you are only a couple of miles from a key account it is unlikely you will get one
Also have following quantity of SEALANTS & CLEANERS over a 100 Litres not free but very cheap
HG
2 x HG Spot Stain Remover 500ml Stains in Porcelain stone etc
2 x HG Mould Spray 500ml Cleans Black Mould in Baths & Showers
1 x HG Grease Away 500ml Stainless hob backs etc
1 x HG Grout Protector 500ml
2 x HG Grout Cleaner 500ml
5 x HG Cotto Wax Protector for easier maintenance Terracotta 1litre
3 x HG Golvpolish 1litre Satin finish for Quarries/Victorian/Slate
4 x HG Remover 1litre Removes old polish/oil etc deep clean product
3 x HG Quick 1litre Porcelain Cleaner
1 x HG Quick 5litre Porcelain Cleaner
1 x HG Shine Cleans and shines Ceramic /Porcelain etc.
LITHOFIN - all litres unless listed otherwise
7 x MPP Marble Polishing Powder
20 x Eversheen easiest maintenance for Terracotta
7 x Sealant for keeping Terracotta pale for use with Impregnator
6 x Impregnator for Deep seal to Terracotta prior to surface Sealant
6 x KF Tile Polish for Quarries & Victorian (Lithofin equiv to Golvpolish)
3 x Protective Impregnator for porcelain/victorian
3 x Intensive Cleaner
5 x Conditioning Cleaner
3 x Classic Terracotta Primer
1 x Slate Oil for Slate Hearths/Cladding not for use externally or in wet conditions
2 x Wax Off for deep clean Slate Terracotta etc for removing old sealants wax etc.
1 x Care Seal - satin finish for stone
3 x Easy Care neutral ph cleaner for marblr stone etc.
2 x Power Clean cleaning limestone stone etc
1 x Cobblewax - give tumbled marble/trav a lovely long lasting shine
1 x 5litre Cement Away - for removing cement/grout residues - not suitable for marbles/Limetones
1 x 5litre Multi Seal for slate etc
1 x 5litre Resin Seal for Terracotta permanent seal
1 x Oilex 250ml tube - Poultice for removing oil/grease from granite marble etc.
MISC
3 x Ever Build Silicone Eater (mini tubes)
1 x Aquamix Grout Haze Clean up
Regards
David Goff
PM for telephone number.
Stonebro2
Marble Limestone Slate Tumbled Marble
Room lots of above all in Leeds if you can collect
17sq m Oyster Quartz 30 x 20cm
10sq m Tumbled Slate 10 x 10cm
7sq m Cream Marble 45 x 45 x1.5cm
10sq m Crema Marfil Octagon with black marble inset 40 x 40 x 2cm
30 - 80sq m White Limestone
13 pcs 60 x 60 x 4cm Filled Dense Beige Travertine
6 or 7 Pieces Iranian Brushed Travertine 1200 x 900 Chipped on edge could cut down
Dan
Admin
Staff member
Re: Free Original Style Display and Other like New Displays- Tile Donk
I'm okay with this just this once. Though I've removed your phone number so you don't get it stuck on cold calling lists. People will contact via PM.
Stonebro2
Thanks Dan -
Stonebro2
Oh and Sealers sold already :0
salsia23
Are interested in the Original Style displays you have. Have they gone yet?
Stonebro2
Where are you Salsia - North your rep will be Julie Russell South will be Dave Finney
Anyways Julie Russell having them picked up to divvy out.
Stonebro2
01392473000 or speak to rep directly worth doing quite a lot of shops closing / closed recently
Reply to Free Original Style Display and Other like New Displays- Tile Donkeys in the Canada area at TilersForums.com
Dawz84
