Discuss External Miters in the UK Tiling Forum area at TilersForums.com.
E
EXRM1802
Hello All,
I have just been given the contract for 6 flats in my local area by an established builders firm. The tiling required is walls and floors for bathrooms and kitchens, using mostly large porcelain tiles.
My question is that the builders want all external miters put in without trim, and having to cut the tiles at a 45 degree angle.
Because of this and being completly inexperianced with these i negotiated for day rate untill i gathered speed.
Questions
What saw would you recommend?
Is this a black art?
How do you avoid sharp edges?
should i be doing this all the time anyway as it did look bloody good?
am i punching above my weight?
I start in 2 weeks. thank you
DHTiling
mitering edges of tiles is an old school method for ceramics, used before trims were made, but a handy technique on marbles etc. as there edges can be honed with a suitable smoothing block, but this cant be done with ceramics etc, as it exposes the biscuit of the tile thus when not smoothed it will leave sharp edges, tell the builder you advise against this method.. if they insist then a good tile saw is the rubi d200 wet saw, it has an adjutable tilting split bed, so ideal for out of true mitre's... good luck...dave..
Reply to External Miters in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
