drill recomendations
careful with the comparisons if you search for the model number you will notice that some are 1.4ah, some 2ah and others 3ah, all very different batteries:thumbsup:
Had the same probs Kilty, took it back though as it was the chuck that went. Got the hitachi 18vt and 2 drills and not had a problem with mine. Use it all the time on floors on aqua panel np's. Quick recharge time 1hr(but u get two batts as well) was £140 outta screwfix
I was looking at them in toolmonkey Mark, brilliant bit of kit for the money
while I was in there I asked about their website as I thought it would be good for members on here but they havent updated it and dont do mail order at the moment
shame as I have had some good deals off them
They do have a good selection in there and some good deals:thumbsup:
i got an erbauer 24v with 2 batteries, good hammer on it too. 2 yr gaurantee. cost me £130 about 18 months ago. still works like new :thumbsup:
i have bosch and makita
if you want to screw hardie backer then go for an impact driver and combi drill set, the impact driver is a most usefull piece of kit
Hi Kilty If you can go the extra cost, Festool 12 volt or 15 volt.
I have had a 4" tank cutter on the angle attachment fitted to the 12 volt drill. Its got loads of grunt.
I was using the makita 18v 3.ah li-ion LXT drill today that i bought from Ed !
I was putting up cabinets in a bathroom and ensuite plus toilet roll holders etc.
I used a 6mm masonry bit to bore through the glazed ceramics on normal twist then knocked hammer on to drill into the solid walls,wow !! one hell of a drill with two lights too on the front! very highly specced kit with two batteries and a 22 minute charger.
Tags Tags
drill usa
kilty55,
hillhead,
kilty55,
hillhead,
